January 27, 2000, 06:03 |
Boundary condition
I try to simulate the air flow in a greenhouse. I put the geometry of the greenhouse in a larger domain. My question is the type of boundary condition for the upper part of the domain because if I don't define it, gambit treat it as a wall. Thank you very much.
January 27, 2000, 10:29 |
Re: Boundary condition
If I understood your problem correctly you want to model a kind of an atmospheric flow. A good way to model the top of such a problem is the symmetry bc if fluxes through the top are negligible. Otherwise you have to use a pressure boundary (with the correct hydrostatic pressure if you are interested in stratification. If I remember it right, Fluent does calculate a pressure stratification only by setting p_ref=0. Otherwise it is not possible to postprocess the p-hyd_static)
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 06:05 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 04:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 13:26 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 12:44 |
