User defined functions
Old   December 21, 1999, 09:02
Default User defined functions
Tuomas Koiranen
Hello, has somebody used fortran routines in fluent and how they are used in fluent, e.g. in case of adding own fluid property (density, viscosity etc.) correlations ? i did not find enough information about Fluent 4.5 User Guide Manual even about the installation of fortran compiler.
Old   December 22, 1999, 15:23
Default Re: User defined functions
John McKelliget
As far as I know the functions have to be written in C
Old   December 29, 1999, 08:41
Risto Huhtanen
In Fluent 4.5 you have to compile your own version of Fluent code where you have your own subroutines with the code. Find a Makefile somewhere in your fluent4.5-directory and use it for compiling. There are instructions how to add own source terms in Fluent 4.4 manual Vol. 4, Chapter 20.
In Fluent 5 (UNS) there is (unfortenately) no way to add Fortran subroutines to the code. In principle it is possible to call Fortran routines from C-routines, but you have anyway to build an interface between Fluent platform and your subroutine. Then you have to use compiled routines, not interpreted option.
USER DEFINED SCALARS yann Phoenics 6 November 14, 2013 09:46
Creating new user defined material Vidya FLUENT 4 August 26, 2013 10:26
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 12:31
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 19:18
Source term for user defined scalars Mech.eng. Siemens 0 March 16, 2006 07:15
