December 3, 1999, 09:03 |
non positive volumes
Dear Friends,
I have made an axisymmetric geometry with the help of gambit.But when i read this mesh file in Fluent5.o it gives warning the non positive volumes exist.What is meant by that .How it can be solved.Please response soon. pankaj |
December 3, 1999, 10:06 |
Re: non positive volumes
It probably means that your grid is bad - go back to gambit and check the quality (click on the "mirror-glas" icon down to the right). Identify where you have bad cells (skewness>=1) and try adjust the gradings etc. to fix it.
December 3, 1999, 11:10 |
Dear friends and Jonas,
Thank you for your fast response.However i got the actual reason for the negative volumes.I was told that whenever imake axisymmetric grid,my centreline or axis of symmetry should be X axis and Whole of geometry should be above the y axis .when i did this i Didn't got any warning. I also want to know that is it required that when an axisymmetric geometry is made ,you have to connect the axis of symmetry on either side to the domain where i want to do my analysis.Please response as soon as possible. pankaj |
December 3, 1999, 14:48 |
I would like to add a few comments on pankaj' last message. I had the same problem about non positive volumes which vanished after I made the problem axisymmetric about the X-axis. However even after doing that sometimes it stills gives an error while reading in the grid. This can be fixed by translating the entire grid by a very small extent in the " positive y-direction ". (Its wierd since when you check the fluent domain extents it doesnt give the y-extent as negative..!..but never the less it works.)
December 6, 1999, 10:42 |
I agree with Jonas that negative volumes usually show up due to a bad grid, i.e. inappropriate meshing density..
You can however try to fix this problem inside of the solver by doing a repair-facehandedness(rfh)..This is under : grid > modify-zone > rfh Once you do this, check the quality of the grid to see if any negative volumes still show up..If they do, you will have to go back to the pre-processor and adjust the mesh density. |
Grid check failed (non positive volumes). | Muhammad Usman Qureshi | FLUENT | 5 | September 26, 2013 07:26 |
[GAMBIT] Connecting volumes | makaero | ANSYS Meshing & Geometry | 4 | April 15, 2010 20:18 |
non positive volumes exist | Moke | FLUENT | 1 | July 7, 2006 09:20 |
Ghosts Volumes on Gambit ?!! help please | Andres D. Ortiz | FLUENT | 0 | October 7, 2001 20:17 |
union of volumes | CHUBBY | FLUENT | 2 | May 4, 2001 07:31 |
