November 30, 1999, 11:01 |
Grid-checking issue in Fluent
When checking my 2D grid under Fluent 5, I get the following message : "Warning ! Non positive face area exists."
My minimum face area equals zero. The grid seems ok, since no nodes are redundant. I really can't understand why a face area is detcted. Any idea ? Thanx in advance. vince |
December 2, 1999, 21:55 |
Re: Grid-checking issue in Fluent
Fluent France should be able to help you with this. You may need to send the grid file to them.
December 3, 1999, 09:15 |
You probably have a collapsed cell somewhere in your grid. I suggest that you bring it back to the pre-processor and check the quality of it.
December 4, 1999, 21:56 |
Hi, I think you should used the Tgrid to check the mesh,it will help you check you mesh. wang haiggang
HELP! grid check failed in parallel fluent | restart | FLUENT | 0 | March 5, 2011 09:55 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
LES on unstructured grid in fluent | Zafer Zeren | FLUENT | 0 | December 20, 2005 06:45 |
Problem on building grid operation (fluent) | remy | FLUENT | 0 | April 12, 2002 10:37 |
Grid for Fluent v.4 using Gambit? | Ray | Main CFD Forum | 3 | October 27, 1999 12:35 |
