November 22, 1999, 11:41 |
reference value
Dear friends,
I am a new user of Fluent.I find it difficult for me to get accurate Cl,Cd and Cm even in very simple cases: 1.2-D Euler equations Naca-0012 airfoil Mach infinite = 0.8 Alpha = 1.25 degree 2.3-D Euler equations M6 wing Mach infinite = 0.84 Alpha = 3.06 The Cl,Cd and Cm obtained using Fluent can be much larger or less than the values pointed by many reference.I think I choose the right refernce value. Could you tell me why? Thanks in advance. Xia Jian |
November 23, 1999, 01:14 |
Re: reference value
First check the reference values for velocity, area... and look then at the exact fluent-definition of cl, cd and cm in the manual. chris
November 23, 1999, 10:35 |
Drag Predictions
Hello Xia,
I have also had difficulties predicting drag using Fluent(5). I am ultimately interested in engine intakes, but to start off ran simulations of simple 2 and 3D shapes for which I knew the drag coefficient. I found I could get the correct values for drag coefficient and drag force, but only after a lot of y+ adaption, even when I had predicted the size of the first cell as Fluent recommended. My concern is that when I am modelling something I don't have the answers for, how will I know when I reach the correct result? I would appreciate any suggestions people out there have since I know I will have more work coming up in this field. All the best and good luck with your simulations. I would be very interested to hear how you get on. Althea |
November 23, 1999, 12:04 |
Re: Drag Predictions
Drag coefficient is affacted by discretization order (depending your mesh)and turbulance models. My suggestion is that using high order discretization ( for example 2.order or QUICK for momentum)and powerfull turbulance models like Realizable k-e. Ali, |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
