How to Solve Issue with /file/read-case in Fluent Journal File
Old   Today, 13:15
Unhappy How to Solve Issue with /file/read-case in Fluent Journal File
Ciceliya is on a distinguished road
Hi everyone, I’m new to Fluent and recently encountered a strange issue.
When I run the following command in the console, it works perfectly and proceeds to the next step without any issues:
/file/read-case ./ccfourth.cas.h5
However, when I include the same command in a journal file (.jou), it starts throwing errors. This happens whether the command is run alone or with other commands in the journal file.
Here is the error message I get after the .jou file runs:
parallel,
Done.
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
If I replace it with the following command in the journal file, it runs without errors, but it is not suitable for non-GUI (no-gui) operations:
(cx-gui-do cx-set-file-dialog-entries "Select File" '( "ccfourth.cas.h5") "CFF Case Files (*.cas.h5 *.msh.h5 *.MSH.h5 )")
Some additional details:
The case file is around 90 MB.
It contains a UDF (user-defined function).
Does anyone know how I can resolve this issue for non-GUI execution? Any help would be greatly appreciated!
Ciceliya is online now   Reply With Quote
file-read-case error, fluent
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
