Generating non-conformal mesh for sliding mesh when moving domain is a sphere |
December 11, 2024, 11:59 |
Hi, I am trying to perform an external flow analysis of a rocket. To find the damping, I need to run transient pitching and rolling simulations. I am using a sliding mesh approach. However, I cannot get Ansys fluent meshing to detect the face zones properly and create a non-conformal mesh, specifically when the moving domain is a sphere. Everything works correctly when the moving domain is a cylinder.
My method for generating the geometry consists of the following:
Below are the results of this process when using a sphere as the internal sliding mesh interface or a cylinder as the interface.
When clicking generate surface mesh task in the cylinder case:[LIST][*]This works as intended: No new 'fair-field:xxx' face zone is created.[*]Non-conformal mesh between objects is available in describe geometry[*]Finishing meshing and switching to solution mode shows that all the boundaries are generated properly and that a sliding mesh analysis can be run. If anyone has an idea why there might be a difference between these two cases, please let me know. It seems like a bug or error to me. The only difference I can think of is that in the case of the cylinder interface, there are a number of edges present, while in the case of the sphere, there are no edges. While waiting for a reply, I will try imprinting an edge on the sphere to see if that changes the results. Using a sphere as an interface is rather important for me as I need to be able to rotate the inner sphere in arbitrary directions. Generating a new mesh with a cylinder perfectly matching each angle would be basically impossible. Please note that I have also tried several different ways of generating the same input geometry. For example, I created the whole enclosure and sphere and then used the combine tool, or I manually created every solid. Either way, the results are the same. |
ansys-fluent, meshing, non-conformal, sliding mesh |
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 12:16 |
[blockMesh] Floating Point Exception while generating wedge based mesh | jns-v | OpenFOAM Meshing & Mesh Conversion | 9 | July 8, 2021 06:36 |
Domain moving without mesh updating | m_mehrdad | CFX | 0 | February 21, 2020 03:46 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 09:09 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
