DPM and EWF
Old   November 29, 2024, 04:28
Default DPM and EWF
zygao
zoey gao is on a distinguished road
I use a DPM surface jet source to spray liquid water onto the wall at a certain flow rate, and open the EWF model on the wall, hoping to obtain the thickness of the wall film after spraying for 30 seconds. The wall surface is not smooth, but has bumps and undulations, used to simulate the road surface of real life. But in the final result, the thickness distribution of the wall film showed a spot like pattern, which obviously does not conform to the actual situation. What is the reason for this? How can I solve it?
The number of mesh on the surface of the jet source is greater than the number of mesh on the wall
zoey gao is offline   Reply With Quote
dpm, ewf, film thickness
VOF EWF DPM Coupled simulation aronCFD Fluent Multiphase 0 July 28, 2024 17:08
Error in DPM injection ! mondal124 FLUENT 0 June 1, 2022 20:47
Eulerian wall film model with DPM dan86 FLUENT 5 June 13, 2016 04:26
Eulerian Wall Film (EWF) Manathan FLUENT 0 August 3, 2015 05:58
