Residual monitor problem when using 'SOFC Model with Unresolved Electrolyte'
Old   November 27, 2024, 22:11
Default Residual monitor problem when using 'SOFC Model with Unresolved Electrolyte'
yibinzhang
zybanss is on a distinguished road
Dear friends:
For example, the residual monitor displayed normally after .msh imported fluent and before 'SOFC Model with Unresolved Electrolyte' model was turned on. However, after turning on the SOFC Model with Unresolved Electrolyte model, the residual monitor looks strange.
I don't know how to upload the screenshot, so I try to describe my problem.
The residual monitor only shows continuity, x/y/z-velocity, energy, h2o, h2, o2, uds-0, but cannot change the value, even the default value can not be seen.What causes the problem?Any suggestions will be highly appreciate.
zybanss
zybanss is offline   Reply With Quote
residual, sofc
#0 prinStack(Foam::Ostream&)sh:1 addr2lin: not found addr2line failed jerrry51 OpenFOAM Running, Solving & CFD 0 September 2, 2022 15:33
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
