2D simulation of floating solar panels with cross-cut fins
Old   November 27, 2024, 15:07
Question 2D simulation of floating solar panels with cross-cut fins
Sulthan Muhammad A.
Krakatoa is on a distinguished road
I have a problem in my research.
I simulate FPV with cross-cut fins in 2D. The fin arrangement is attached to the bottom of the panel with a staggered arrangement. (in the technical drawing.png image). then I make it 2d with a geometry display (in the 2d_geom.png file). if I make it 2d with that display, is the use of fins in my case the same as the staggered arrangement in 3d simulation?
sorry if my words are not easy to understand.
Krakatoa is offline   Reply With Quote
fin, floating photovoltaic
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Floating point error with Solar radiation Ruzic STAR-CCM+ 1 December 21, 2012 15:38
Solar Panel Water heating using solidwork Flow Simulation axtray FloEFD, FloWorks & FloTHERM 2 September 21, 2011 16:47
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 11:31
multiphase simulation floating point error vidhya Main CFD Forum 0 April 11, 2011 00:18
