Conjugate (with Solid Domain) vs Fluid Domain Analyses
Old   November 27, 2024, 07:38
Default Conjugate (with Solid Domain) vs Fluid Domain Analyses
HK-Paz
hayatikadirpazarlioglu is on a distinguished road
Hello Dear All,
I tried 2 different simulations for the same boundary conditions.
One of them was included solid body (Heat Exchanger) to do conjugate heat transfer analysis. I got my results.
then, I wanted to try only for fluid domain to compare with conjugate heat transfer analysis's results.
I did not change any boundary conditions, just I suppress my solid body which is around my fluid domain. then I started simulation.
When I obtained the results coming from fluid domain analysis,
I saw there are differences for Pressure Drop, Friction Factor, Average Wall temperature, and Nusselt number.
I was expecting, it should give the same results with Conjugate heat transfer analysis.
Do you have any idea why I could not achieve this?
hayatikadirpazarlioglu is offline   Reply With Quote
ansys fluent, conjugate heat transfer, fluid domain, heat transfer, laminar flow
Conjugate Heat Transfer: Solid Time Step in Transient Simulation, DO Model Dingens FLUENT 0 July 9, 2021 07:19
Conjugate heat transfer virothi Main CFD Forum 10 January 5, 2021 05:46
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
