The mass nonconservation caused by the moving mesh
Old   November 27, 2024, 02:24
Default The mass nonconservation caused by the moving mesh
WEBEER
yber is on a distinguished road
Dear teachers, I am conducting a simulation of compressing ideal gases using an internal combustion engine grid. My 3D compression chamber model has no inlets or outlets, only walls. When the time step is 10e-05, the average air mass in the compression chamber is nearly constant, but the calculation is too large. When the time step is adjusted to 10e-04, the average air mass in the compression chamber will drop significantly, resulting in a large error in the calculation results. What's going on? Here are my model diagram, residual diagram, and mass change diagram.
https://picture.gptkong.com/20241127...cc891b5f29.jpg
yber is offline   Reply With Quote
compress air, dynamic mesh, mass defect
Position and Forces in a Transient Problem with a Moving Mesh astrakhan FLUENT 3 July 17, 2023 10:22
3D CFD Sliding Mesh Problem, nodes on the interface side not moving. vaibhavvsr FLUENT 0 March 1, 2023 07:48
Moving mesh simulation with mesh changes inside the solver cgoessni OpenFOAM Programming & Development 2 January 24, 2022 10:14
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
CavitatingFoam with a moving mesh mass conservation error idosil OpenFOAM Running, Solving & CFD 3 November 27, 2007 18:27
