Heat Transfer in a Battery Segment
Old   November 24, 2024, 08:11
Default Heat Transfer in a Battery Segment
Luc Bernhardt
lucbrnhrdt is on a distinguished road
Hi everyone,
I’m currently running a CFD simulation to analyze the heat transfer in a battery segment composed of lithium cells. Here are the key details of the setup:
Model: k-epsilon turbulence model with energy equation enabled.
Heat source: On each cells, defined as a source term corresponding to the power dissipated in the cells, specified in W/m³ based on use cases.
Mesh: Focused on the positions of the cells, with a volume enclosure around the segment.
Boundary conditions:
Inlet: Velocity of 7 m/s with an air temperature of 35°C.
Outlet: Pressure outlet with air exiting at 35°C.
The simulation runs fine overall, and the air temperature rises as expected while passing through the segment. However, I’m observing an issue: the cells closest to the inlet are unexpectedly the hottest.
I’ve checked the inlet and outlet configurations, and they seem correct since the air is clearly heating as it moves through the segment. The mesh quality is good as well. I also have the radial and axial thermal conductivity values and the specific heat of the cells.
Does anyone have an idea what could be causing this behavior? Could it be related to turbulence modeling, heat transfer mechanisms, or something I might have overlooked?
Thanks in advance for your help!
lucbrnhrdt is offline   Reply With Quote
battery, battery segment, cells, cfd, heat transfer
Heat transfer coefficient in regenerator gartz89 FLUENT 0 May 26, 2018 02:23
Flow around heatsink with heat transfer S Mughal FLUENT 0 April 13, 2018 14:06
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Question about heat transfer simulation Anna Tian Main CFD Forum 0 January 25, 2013 19:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
