Issue with Contour Discontinuity When Using a Dynamic Mesh
Old   November 20, 2024, 01:45
Default Issue with Contour Discontinuity When Using a Dynamic Mesh
Muhammed Sadique Parancheerivilakkathil
muhdsadiquep is on a distinguished road
Hi all,
I am encountering an issue with contour plots for a pitching airfoil simulation (using a dynamic rotating mesh). The contour shows a discontinuity between the dynamic mesh zone and the background mesh. Please refer to the attached image for clarity.
Additionally, the contour plot displays the edge of the dynamic mesh zone, even though I did not select it when defining the contours.
Can anyone assist me in resolving this problem? I am saving the contours at each time step by defining an animation under Solution Animations (in Calculation Activities) and exporting them as JPEG or PNG files. Would using ANSYS Ensight for postprocessing help address this issue after saving the files as HSF?
I also tried selecting only the background mesh and airfoil boundaries (excluding the dynamic mesh zone), but this created a gap (an empty region) between the airfoil boundary and the background mesh in the plot.
I need to use the dynamic mesh option for this simulation because I plan to simulate passive airfoil motion later (the current simulation shows active motion).
Any suggestions would be greatly appreciated!
Regards,
Muhammed Sadique
muhdsadiquep is offline   Reply With Quote
contour, discontinuity, dynamic mesh
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
Postprocessing issue with dynamic mesh? ghost82 FLUENT 1 November 2, 2012 11:06
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
