November 12, 2024, 18:45 |
Specifying hydraulic diameter in 2D
Jen
Hi, this is definitely a stupid question but I don't know how to determine hydraulic diameter whilst working in 2D ie with the geometry modelled as a surface.
I'm modelling an ellipse in a rectangular domain (meant to simulate an external flow). The only value I have to work out HD is inlet height. In the worksheets I'm using, they use intensity & hydraulic diameter as the turbulence parameters but I have no idea how they got their HD value. For reference, they had inlet height 20m & their HD is 1.306m, the bluff body has length 0.6096. |
November 14, 2024, 10:07 |
Luca
Rep Power: 5 |
Hydraulic diameter is meant to be used mainly for internal flows, in your case it would be better to evaluate the turbulence parameters through turbulent viscosity ratio.
https://www.simscale.com/forum/t/def...nditions/80895 Here you can find some infos. |
How to calculate Turbulent Intensity and Hydraulic Diameter for my problem? | Roh | FLUENT | 1 | June 17, 2018 04:12 |
diameter equivalent and hydraulic diameter | medaouarwalid | Main CFD Forum | 6 | June 22, 2017 03:33 |
[GAMBIT] hydraulic diameter? | Zweeper | ANSYS Meshing & Geometry | 6 | January 4, 2010 01:44 |
hydraulic diameter in 2d | ahsan | FLUENT | 2 | August 28, 2009 16:22 |
Importance of Hydraulic Diameter Value for Compressible Flow | RyGuy | FLUENT | 0 | August 6, 2009 11:58 |
