Running fluent with distributed memory on a Cluster option
Old   November 12, 2024, 06:22
Default Running fluent with distributed memory on a Cluster option
drasszkusz is on a distinguished road
Hi all,
I am trying to run Ansys Fluent 2024 R2 in distributed mode on two computers.
Computer 1:
AMD Ryzen 9 7950X
64 GB RAM
NVIDIA RTX A4000
Windows 11
Computer 2:
AMD Ryzen 9 7950X
64 GB RAM
NVIDIA Quadro 4000
Windows 11
I have followed the instructions of a previous thread: [TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines
Same username and password on both computers, same Ansys and Intel MPI versions are installed at the same path. I have also checked the recommended Intel MPI version for the Ansys version and the correct one (2021.8.0) is installed.
The whole C: drive is shared both on Computer 1 and Computer 2. Credentials were registered from both sides.
The problem is that I can't run fluent using both computers' resources. I can run Fluent from Computer 1 using Computer 2's resources and back, but when I specify to run 4 cores on Computer 1 and 4 cores on computer 2 then I get an error message (see attached photo Error messgae.png). It does not matter how many cores I specifiy, there is a problem when I would like to use both computer's resources. Individually they work well.
Thank you in advance for any suggestion that can solve this!
drasszkusz is offline   Reply With Quote
cluster setup, distributed parallel, fluent
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Radiation interface hinca CFX 15 January 26, 2014 18:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
