Error: "Setup component in Fluid requires user input" issue
Old   November 8, 2024, 03:34
Exclamation Error: "Setup component in Fluid requires user input" issue
Evan Zhang
evanzhang08 is on a distinguished road
Hi - I am relatively new to Fluent and this forum. Any help would be greatly appreciated and I would be incredibly thankful.
I am trying to model a liquid-filled closed cavity in which the changing in shape of the solid body surrounding the liquid shifts and causes a change in the liquid. The liquid's movement then causes further change to the shape of the solid body. I am attempting this using the System Coupling feature of Ansys. I have completed the structural, solid part of the simulation and am currently trying to model the liquid in Fluent.
When meshing the liquid, I suppress the solid portion of the simulation.
I've created the material and defined the cell zone as the desired material, and I established the boundary condition for the wall as a No Slip Moving wall (the only boundary condition it allows me to edit). I've set the solver to the desired type (Pressure) and Ive also defined a dynamic mesh.
In the Solution tab, I've set the methods to the "coupled" scheme and left everything else as default.
When I click the t=0 initialize button, it tells me in console that initialization is done.
In the Run Calculation menu, I increase the number of iterations.
When I return to workbench and try to update the Setup, it says that "Setup component in Fluid requires user input before it can be updated." I can not seem to solve this issue even after going back through the steps listed above. Is there something I am missing here, or am I simply doing something wrong?
Thank you all in advance.
evanzhang08 is offline   Reply With Quote
Error: Update failed for the setup component in Fluid Flow CFX nudi1001 CFX 4 January 17, 2023 04:01
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Update failed for the Solution component in Fluid Flow (Fluent). The Solution compon Faiz94 FLUENT 1 June 10, 2019 17:17
Issue in simulation of open channel flow with high viscosity fluid soleymm1 STAR-CCM+ 2 December 3, 2017 02:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
