Can Fluent be used to simulate multiphase flow simulation with microscale below 1 mic |
October 30, 2024, 03:20 |
Yuhan
Rep Power: 2 |
Hi everyone,
I have a case which has a very special physical model: basically it is a droplet between two solid plates, the upper plate would lower and squeeze the droplet to spread. The size of plate is about 100mm*100mm, but the initial gap between the plates is 1μm, and it would be smaller with the squeezing process (basicaly its is a liquid film). So the fluid field is around 100*100*0.001, I wonder if the tiny scale like this could be simulated in Fluent? (I plan to use VOF model in Fluent) Thank you for your replying and advices! Last edited by M.W; October 30, 2024 at 03:22. Reason: typo |
fluent, micron, microscale, mulitphase, vof model |
Unsteady Subsonic Nozzle Flow Simulation Issue with SU2 | Madsskjaerbaek | SU2 | 3 | April 17, 2024 10:41 |
"steady/repeat periodic flow" from transient simulation for multiphase flow ? | yylaw | Fluent Multiphase | 0 | April 10, 2024 04:41 |
multiphase flow simulation | razika | Fluent Multiphase | 0 | September 19, 2018 18:57 |
Thermal Simulation using Multiphase VOF model in Fluent | hari.poudyal47@gmail.com | Fluent Multiphase | 0 | July 20, 2015 12:31 |
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 11:13 |
