Modeling of water pump without 3D CAD
Old   October 29, 2024, 02:10
Default Modeling of water pump without 3D CAD
Venkat Anumula
enr_venkat@yahoo.com is on a distinguished road
Hello All,
We are working on an Electric Vehicle Traction Cooling System (TCS). Accurate modeling of water pump is crucial in addition to the heat sources. Unfortunately we would not be able to get 3D CAD Model of the pump as it is a proprietary part.
How do we model the pump in such cases ? As an alternate workaround, we tried to model the pressure jump as in case of fan using ANSYS FLUENT. The solution diverged at the start of fan. However, i found few articles from ANSYS regarding the same to avoid divergence.
Is this approach applicable for Pump ? Since it's a positive displacement pump, the flow gets induced in a closed system whereas in case of Fan, the flow enters and exits on the other side which is open to fluid stream on both sides.
Any ideas and fairly accurate methods would be really helpful.
enr_venkat@yahoo.com is offline   Reply With Quote
Old   November 7, 2024, 21:13
Default Consider a momentum source?
Hector Maldonado
DigiHctrGT is on a distinguished road
Is your simulation domain in 3D? I've had some experience with the pressure jump, and I must say I faced the same problems as you. What made the trick in my simulation was to use a moment source. Given the cross-sectional areas of the inlet and outlet and the hydrostatic head from the manufacturer, I could approximate the effect of an axial pump defining this in the section where the pump would be placed. I lowered the momentum control for a while, and once the simulation seemed to be converging, I increased it.
I hope this idea helps.
DigiHctrGT is offline   Reply With Quote
ansys fluent, pump data, pump simulation, water pump
How to use a UDF to set the volume fraction in the cells next to a wall? DF15 Fluent UDF and Scheme Programming 33 August 20, 2020 14:36
Pump CAD + experimental data for CFD verification study bemism Main CFD Forum 0 July 20, 2017 16:30
Modeling electrochemical reactions for water treatment Many FLUENT 2 March 16, 2017 05:07
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 10:29
