Pumping ring mechanical seals
Old   October 24, 2024, 06:46
Default Pumping ring mechanical seals
fraperon is on a distinguished road
Hi everyone, I'm currently working on simulations regarding pumping ring in mechanical seals.
More specifically, I'm using Fluent to simulate the mass flow rate pumped by the rotating shaft and compare it to some experimental results.
For my cases, I did simulate only the fluid volume, imposing a rotating wall boundary condition for the innner part of the volume, plus an inlet and outlet pressure conditions (they are the only known variable). The simulation type is steady state
My CFD results are quite accurate, since i get about 10-15% difference from the real experiments.
My question is: is it correct to impose the rotating wall velocity b.c. or is it necessary to implement something like two frames of reference? (I read about this in a paper regarding a similar topic)
Thanks in advance
fraperon is offline   Reply With Quote
mechanical seals, pump boundary condition, pumping rings, rotating wall velocity
Hardware Suggestions for Ansys Mechanical, Sherlock and Mechanical Kips Hardware 8 October 17, 2022 18:57
Best HW for ANSYS 2 HPC in CFX and Mechanical Youpi Hardware 4 May 20, 2021 10:42
How to Import Volumetric Loss from Maxwell to ANSYS Mechanical 2013 mtajeldin ANSYS 0 October 29, 2015 05:49
[ANSYS Meshing] Script Model - Mechanical USER1234 ANSYS Meshing & Geometry 33 September 25, 2015 10:19
Mechanical fails, MAPDL doesn't..FSI KeganLeckness Structural Mechanics 0 August 17, 2015 17:34
