Cooling time error
Old   October 24, 2024, 03:27
Default Cooling time error
DP Pham
DP_Pham is on a distinguished road
Dear all,
I am performing fluent with VOF to simulate the heat transfer. However, after heating, the material cool down till the liquidus temperature and keep remained at the temperature. It did not cool down to room temperature even I set the long time for cooling. Do anyone have idea to solve this problem?
Thank you so much
DP_Pham is offline   Reply With Quote
fluent, heat tranfer, lpbf, slm
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
