October 21, 2024, 12:10 |
Fluent battery heat generation fitting
if anyone has conducted simulations and experiments for heat generation verification? My experimental parameters are similar to the S-type, but the simulated curve is nearly linear. Whether I import internal resistance heat generation using UDF or directly fit the experimental parameters into a formula and then import it into Fluent, the trend of the simulated curve is always nearly linear. How can fit it so that the heat generation curve in Fluent approximates the experimental results?
The above figure shows the simulation curve, while the below figure shows the experimental curve |
October 22, 2024, 03:28 |
Moritz Kuhn
Rep Power: 17 |
Maybe the S-type depends on other temperature-dependent data. As thermal conductivy of your solids, chemistry inside the battery, small amounts of evaporating water and so on. So it could be not a problem of setting up the heat generation in Fluent.
bettery |
Heat Generation Rate (W/m^3) to Heat Load (W) | pawandeep94@gmail.com | Main CFD Forum | 0 | November 18, 2023 07:50 |
Importing Heat Generation .CSV in Fluent | Lorenzo Basili | FLUENT | 0 | February 12, 2021 14:28 |
heat generation inside battery | ramin9512 | Fluent UDF and Scheme Programming | 3 | January 25, 2021 01:55 |
Fluent Tutorial on Heat transfer | Far | FLUENT | 15 | July 29, 2017 16:31 |
Heat Generation rate in W/m³ | ashghan | OpenFOAM Programming & Development | 0 | June 27, 2014 06:42 |
