Pressurization of a tank (ANSYS Fluent)
Old   October 18, 2024, 10:36
Default Pressurization of a tank (ANSYS Fluent)
Gaétan
Mahk is on a distinguished road
Hello everyone,
I am trying to model the pressurization of a 50-liter air tank, initially at atmospheric pressure, and raised to a pressure of 12.5 bar by a compressor, with an injection pressure of 12.5 bar into the tank. The objective is to determine the time required to reach 12.5 bar in the tank, as well as to capture the mass flow rate and the fluid velocity at the injection point.
On paper, my model is quite simple. It consists of a 50-liter cylindrical tank. A pressure inlet (Gauge: 1,148,675 Pa) with a passage area of 12 mm. The air density follows the ideal gas law, with a temperature of 303.15 K, and the rest of the properties are constant. The energy equation is activated. Turbulence model: k-w SST. Pressure-based resolution.
The calculation converges; however, the pressure evolution in the tank seems inconsistent to me. It follows a linear behavior and only approaches an asymptote near the injection pressure. If we look at the flow rate, it remains constant and only drops to zero when the pressure reaches its asymptote.
Physically, the pressure increase in the tank should slow down as the pressure rises. Similarly, the flow rate should decrease in response to the rising pressure.
Do you have an explanation for this result? And how can it be corrected?
Thank you for your responses,
Mahk
Mahk is offline   Reply With Quote
pressure based, pressurised tank problem
Tank emptying problem using Ansys Fluent Tanjina FLUENT 13 January 1, 2023 08:22
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Sloshing of Fuel Tank in ANSYS FLUENT 14 RADHEESHD FLUENT 1 February 5, 2015 02:32
Fluent & Ansys FSI architecture help DillonS FLUENT 1 April 7, 2010 17:00
