Report - Mass Flow at Outlet Boundary
Old   October 17, 2024, 20:40
Default Report - Mass Flow at Outlet Boundary
Dee Kay
Dee Kay is on a distinguished road
Hi All,
I am simulating a compressed air pipe flow in a long meandering pipe network with an operating pressure of ~ 650 KPa.
I am plotting the mass flow rate at the outlet and it has this profile attached. I've also attached the absolute pressure plot at the same location.
What is the physical interpretation of this plot? I expect a Mass Flow rate of ~ 65 kg/ s at this location.
Thank you for assisting.
Dee Kay is offline   Reply With Quote
Old   October 18, 2024, 08:36
Moritz Kuhn
MKuhn is on a distinguished road
You get it. I can't say exactly, as the grid lines are missing, but it should be around 70 kg/s. The pressure drop is around 94 kPa. You have the operating at the inlet and the absolute pressure at the outlet. Since the pressure at the outlet is higher than at the inlet, your medium flows in the opposite direction. This is reason, that you have a negative massflow in your plot.
MKuhn is offline   Reply With Quote
cfd - post, converge, residual oscillations
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
