Saving Solution animation as PNG in batch mode
Old   October 9, 2024, 10:49
Question Saving Solution animation as PNG in batch mode
Sajeed hussain
Sajeed Hussain is on a distinguished road
I am running a sim in batch mode (2021r2) and I have set instructions both in case file and journal to save solution animation as PNG. But the images are not saved.
These are the commands in the journal:
/file/set-directory /
/display/animate/storgae-type png
/display/animate/set-interval 1
/display/animate/save
and for batch _ fluent 2ddp -g -t -cnf -i file.jou
I do not understand if I'm missing something.
Thank you for the help.
Sajeed Hussain is offline   Reply With Quote
Old   October 16, 2024, 03:53
Moritz Kuhn
MKuhn is on a distinguished road
Hi Sajeed,
I have done the same thing several years ago. Here is a part of my batch file, hopefully it will help you:
/display/set/contours/filled-contours yes
/display/set/picture/driver png
/display/set/picture/landscape yes
/display/set/picture/invert-background yes
/display/set/picture/use-window-resolution yes
/display/set/picture/color-mode color
/display/set/colors/skip-label 1
/display/set/contours/clip-to-range no
/display/set/contours/coloring no
/display/set/windows/axes/visible no
/display/set/windows/text/visible yes
/display/set/windows/scale/format "%0.0f"
/display/set/contours/surfaces sweep-surface-7 ()
/views/restore-view film50
/display/contour temperature 120 278
;set up display commands to print front view of phases and velocity magnitude every time steps
/solve/execute-commands/add-edit command-1 1 "time-step" "/display/views/restore-view film50"
/solve/execute-commands/add-edit command-2 1 "time-step" "/display/contour temperature 120 278"
/solve/execute-commands/add-edit command-3 1 "time-step" "/display/save-picture /home/kuhn/Vita/vitafilm1/temperature-%t.png"
--Moritz
MKuhn is offline   Reply With Quote
animation solution, batch simulations, fluent
Creating animation in batch mode lmtlmt12@yahoo.com FLUENT 0 April 30, 2023 13:56
Solution Animation RF_ FLUENT 0 August 31, 2021 02:07
Fluent Batch Mode error: No error handler available hahs FLUENT 0 September 14, 2018 02:29
Saving of monitor points in batch mode. Martijn CFX 3 December 10, 2008 11:36
batch & solution animation Paolo FLUENT 0 May 5, 2003 06:58
