2D Savonius hydro turbine validation stall point issue |
October 9, 2024, 04:37 |
Adarsh Parasuram
Hi everyone,
I am currently working on Savonius hydro turbine in 2D. During my validation I noticed that up to the stall point, the trend is following, but after the stall point the Cp is still increasing. I have tried different methods like changing the scheme, turbulence model, gradients and validation paper also. Still I persist the same issue. My wall y+ is also <1. It can be seen from the images that at TSR 0.6 where it is matching with experiment, my streamlines are connecting outside and inside the MRF, while at after stall point it is not. (ignore fluid air, I manually input the values of water and did not change the name). My my mesh count is closer to 0.37 million which can be seen in literature also for 2D case. The boundary conditions are symmetry sides and pressure outlet with blades as wall. (negative omega as it is rotating in Clockwise direction). Can someone please help me, I am stuck in this for te past 3 months.validation graph.JPG velocity TSR 0.6.jpg velocity TSR 1.1.jpg |
fluent, hydrokinetic turbine, savonius turbine, vertical axis turbine, windturbine |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 19:05 |
Injection initialization generate a segmentation fault!! | zahrae | Fluent UDF and Scheme Programming | 11 | July 9, 2019 20:00 |
[OpenFOAM] Visualization issue with interpolated point data field and periodic (cyclicAMI) BCs | Diro7 | ParaView | 1 | July 24, 2017 09:39 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 12:25 |
