Questions on cyclone simulation
Old   October 8, 2024, 11:35
Default Questions on cyclone simulation
SjBos is on a distinguished road
I'm trying to simulate Stairmand cyclone in Fluent with cyclone diameter of 0.29 m. Some info on my setup:
Mesh and domain:
- Polyhedral mesh with inflation layers. First element height equal to roughly 1.5e-3 [m] to have y+ > 30, and use wall functions.
- Extended inlets and outlets by length of 1D.
- Different mesh refinements 100,000 to 500,000 cells.
BCs:
- Velocity inlet of 10 m/s at inlet.
- Two pressure outlets 0 Pa.
Simulation:
- Pseudo transient: time scale factor around 0.1 - 0.5.
- Coupled pressure-velocity
- Turbulence, start with SST curvature correction. After some initial convergence switch to RSM (linear pressure-strain)
Problems:
- The RSM improves the results and gets it closer to experimental data. However, in the center, the velocity profiles mainly show deviations in the center. I thought mesh refinement would improve it. But the max tangential velocity remains being lower than experimental data. Additionally, the convergence gets really bad and further refinement results in no convergence at all.
- I'm going to time scale factors of like 0.01 just to somehow improve convergence. This can't be right, is it?
- Also, is reverse flow over outlet common in cyclone simulations?
I'm wondering what could be my next steps:
- Switch to low y+ approach (<1) and stop using wall functions?
- Different simulation setup?
- Would it be related to my mesh?
Anyone experienced in cyclone simulations?
Thank you in advance!
SjBos is offline   Reply With Quote
cyclone, cyclone separator, fluent
Cyclone separator simulation Wayne12195 FLUENT 3 August 26, 2019 05:14
LES SpalartAllmaras Simulation questions Matt1986 OpenFOAM Running, Solving & CFD 11 June 15, 2015 07:08
cyclone LES simulation prob: ERROR # 004100018 sakurabogoda CFX 15 November 6, 2012 10:07
About multiphase simulation for cyclone separator Sushil Main CFD Forum 0 July 7, 2007 06:45
Cyclone simulation Jason Main CFD Forum 0 December 6, 2006 06:04
