source term of energy equation in non-equilibrium thermal model of porous media
Old   September 28, 2024, 21:24
Default source term of energy equation in non-equilibrium thermal model of porous media
Fany
yf70512 is on a distinguished road
Hello everyone,
I am trying to modify the source term of energy equation in non-equilibrium thermal model by UDS and UDF (DEFINE_SOURCE macro).
But the Fluent crashed when the code runned with the error "999999:mpt_accept:error: accept failed: No error". My code is as following:
DEFINE_SOURCE(Fluid_source,c,t,dS,eqn)
real Tf, Ts;
real hfs = HFS_CONSTANT; // Placeholder value for heat transfer coefficient
real Afs = AFS_CONSTANT; // Placeholder value for interfacial area density
real source;
// Obtain fluid and solid temperatures
Tf = C_T(c, t); // Fluid temperature
Ts = C_STORAGE_R(c, t, SV_T_S); // Solid temperature
// Calculate the source term based on the modified expression
source = hfs * Afs * (pow(Ts, 4.0) - pow(Tf, 4.0));
// Set the derivative of the source term with respect to Tf
dS[eqn] = 4.0 * hfs * Afs * pow(Ts, 3.0) - 4.0 * hfs * Afs * pow(Tf, 3.0);
return source;
DEFINE_SOURCE(Solid_source,c,t,dS,eqn)
real Tf, Ts;
real source;
source = hfs * Afs * (pow(Tf, 4.0) - pow(Ts, 4.0));
dS[eqn] = 4.0 * hfs * Afs * pow(Tf, 3.0) - 4.0 * hfs * Afs * pow(Ts, 3.0);
return source;
I am not sure if it was caused by the wrong expreesion of reading the solid temperature. Could someone please give me some suggestions? Many thanks.
Best regards,
Fan
yf70512 is offline   Reply With Quote
non-thermal equilibrium, porous media, source terms, uds
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Source term energy equation for reactive flows DaIN Main CFD Forum 0 October 6, 2011 16:11
