Coordinates of the sonic line at the nozzle throat |
September 27, 2024, 07:12 |
Rep Power: 2 |
Dear all,
I want to obtain the coordinates and flow properties along the initial value line [blue arrow: image attached] at the throat so that I can feed it in my MOC code for nozzle design. The current code does not yield a continuous variation in mach number along the centerline (Image attached). I am hoping that maybe by getting the coordinates of the sonic (orange arrow)/initial value line, the code will yield a uniform exit flow. Is there any way to I can obtain the coordinates as well the flow properties in Ansys Fluent? Any help is appreciated Thank you in advance. Last edited by adit_YA; September 28, 2024 at 07:11. |
September 27, 2024, 13:07 |
Rep Power: 13 |
Can you please draw the line you talk about in the image? because I cannot follow
September 28, 2024, 07:16 |
Rep Power: 2 |
October 1, 2024, 17:40 |
Rep Power: 13 |
I am not sure if it is what you want, but you can do an isosurface of whatever you want (maybe velocity?). You will get a contour line.
You can then make a plot on it with the variables you want and write it to a file. Regards |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
