How to export pressure along contour vs. time
Old   September 25, 2024, 19:11
Thumbs up How to export pressure along contour vs. time
GaudyZebra is on a distinguished road
I'm trying to run a 2D transient model of turbulent external flow over a cylinder. I'd like to obtain the pressure over the cylinder surface vs. time. Ultimately, I'd like a 2D array of pressure values, with position (samples along cylinder wall) along one dimension, and time along the other.
In FLUENT and Post, I can plot the pressure over the cylinder surface, and in Post, select the time step. I figured out a way in Post to automate changing the time steps and export the chart data, but it was very slow. Is there a simple way to export this 2D data in FLUENT or Post or EnSight?
GaudyZebra is offline   Reply With Quote
Old   September 26, 2024, 12:18
HHOS is on a distinguished road
Play around in the TUI in order to obtain the command that you'd need in order to create a plot like the one you are mentioning and writing it out to a file.
You can put that command in "calculation activities" to run the command every iteration or timestep.
The filename should include in it %i for iteration or %f for flow time (maybe %t for timestep number, not sure), that way if your file is called "Pressure_on_cylinder_%f.xy", it will replace the %f for the flow time.
If you work with ensight and have a transient export, I would show the plot in Ensight and with the help of a little python script you can go over every timestep exporting the plot.
I don't know if it will help...
Cheers.
HHOS is offline   Reply With Quote
ensight, export data, fluent, post, transient 2d
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
