September 20, 2024, 11:00 |
Parametrized Study and Periodic Boundaries
Eduardo Engelhardt
Hi there.
I'm modeling an annular tube, and I'm parameterizing its eccentricity. The problem is that I'm also using Parametric Boundaries at Inlet and Outlet faces, since it is a permanent regime. It seems that after Ansys jumps to the next design point, the operation that converts those Inlet and Oulet faces to a Periodic Boundary are not replicated. I think it happens because there is a geometric change in periodic boundary faces. Could anyone help me? |
parametric analysis, parametric geometry, parametrization, periodic boundaries, periodic condition |
Problem with Periodic Boundary Conditions during Parametric Study | gfarrell | FLUENT | 3 | April 29, 2023 12:04 |
Applying different periodic conditions to system (two fluid domains) | Jjoyk | FLUENT | 1 | November 26, 2020 21:40 |
temperature gradient in spanwise direction in a periodic channel flow study | backscatter | OpenFOAM Pre-Processing | 0 | September 9, 2019 14:12 |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 02:18 |
3D external periodic multi-zone flow with RANS-based Turbulence model | pdp.aero | SU2 | 3 | February 23, 2014 22:55 |
