RGP table... ansys fluent
Old   September 17, 2024, 04:02
Default RGP table... ansys fluent
Arun raj.S
arunraj is on a distinguished road
Hello everyone, I have created a RGP table for water that i want to use in pipe flow simulation. Can someone tell the exact steps to be followed for using the RGP table to define the fluid material properties..
arunraj is offline   Reply With Quote
Old   October 10, 2024, 09:00
Jack Zhang
blinkman is on a distinguished road
if you are using CFX-pre2024,you can generate rgp files through Tools-generate rgp files.
You can also create RGP table files from the NIST REFPROP material properties using the RGP Generator command line tool.
%AWP_ROOT231%\SystemCoupling\bin\systemcoupling.ba t
Below is a typical example of commands for generating an RGP file:
import pyExt.RefProp as arp
fluidsPath = arp.getFluidsPath()
mat = arp.RefPropLib()
fluidList = ['fluids/water.fld']
mat.setup(fluidsPath, fluidList)
interpError = 1.0e-3
Tmin = 300.0
Tmax = 700.0
Pmin = 100000.0
Pmax = 25000000.0
# Generate both the liquid and vapor components, independent settings possible
h2ollow = arp.RGPLiquid("H2OL", Tmin, Tmax, Pmin, Pmax, interpError)
h2ovlow = arp.RGPVapor("H2OV", Tmin, Tmax, Pmin, Pmax, interpError)
arp.generateRGPfile("H2O-low.rgp", h2ollow, h2ovlow)
blinkman is offline   Reply With Quote
Old   October 10, 2024, 09:45
Arun raj.S
Dear blinkman,
Thank you. I am using. However, in my case, it has failed by SHOWING UPPER LIMIT ERROR. I tried hard but eventually gave up. Though I believe the code is working properly.
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 03:48
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro cheezum Hardware 0 February 28, 2017 11:23
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
