Drag and Lift calculation
Old   September 10, 2024, 22:04
Default Drag and Lift calculation
eddy
tjwldhks79 is on a distinguished road
I understand that in the formulas for drag and lift, different areas are used.
I also understand that this area can be set in the reference values.
In that case, isn’t it impossible to calculate drag and lift at the same time?
Since the areas used for each are different, and there is only one area that can be input in the reference values, shouldn’t we calculate drag and lift separately, one after the other?
However, in the reference videos and materials, it seems that they are calculating both together...
Could you please give me some advice?
tjwldhks79 is offline   Reply With Quote
Old   September 27, 2024, 13:17
HHOS is on a distinguished road
Drag and Lift coefficients are given using a reference area, the same one for both.
The area is the cross section of the body, perpendicular to the flow direction. Now, that area would vary depending on the direction of the flow, but then the coefficient would give you a little information if you are to compare two situations. Hence that value is fixed and the dimensionless number is the one adopting the change, so that you can compare stuff.
You can also obtain the forces in N instead and work with that if dimensionless numbers are confusing.
Maybe helps, maybe not
HHOS is offline   Reply With Quote
Lattice Boltzmann: Drag and lift calculation when varying number of lattices AdvancedSimulation Main CFD Forum 0 May 29, 2024 06:11
drag and lift coefficient calculation kip_396 FLUENT 0 March 30, 2024 01:36
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
Drag and lift calculation in Arbitrary Mesh Interface simulation anon_q OpenFOAM 7 April 22, 2018 14:24
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
