September 4, 2024, 16:10 |
Help About Wankel Engine UDF
Emre
I am designing a wankel engine within the scope of a project and I want to use ansys fluent to analyse this engine.
In order to rotate the rotor of the wankel engine in the body, I found a UDF on the forum and made changes according to my own engine. However, the UDF does not work correctly. Although the rotor rotates in the body at the speed I set, I have some problems with translation and therefore the rotor goes out of the body. I would be very happy if there is someone who can help with this issue. The UDF I use: [CODE]#include "udf.h" #define r 0.0011 /*Eccentricity*/ #define k 57.2727 /*rad to degree*/ #define w 0.001 /*rad/sec*/ DEFINE_CG_MOTION(rotor, dt, vel, omega, time, dtime) { real beta; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); omega[2] = 0.001; beta = 0.003; vel[0] = -beta * r * cos(beta * time); vel[1] = beta * r * sin(beta * time); vel[2] = 0; } Body Center: https://hizliresim.com/jthkp21 The rotor moves out of the body: https://hizliresim.com/4a5a6gc |
udf, user defined function, user defined functions, wankel, wankel rotary engine |
Heat flux estimation for a liquid rocket engine - UDF | Vijay_01 | FLUENT | 5 | June 21, 2024 06:49 |
ParaFoam not responding on mac | Abhisek | OpenFOAM | 0 | May 7, 2022 12:15 |
UDF compiling error | Weiqiang Liu | FLUENT | 2 | November 21, 2018 09:36 |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 11:29 |
