2d laminar pipe flow
Old   September 2, 2024, 04:08
Default 2d laminar pipe flow
Sangkyu Baek
skbake94 is on a distinguished road
Hi friends,
I'm trying to run a 2d laminar pipe flow simulation on ansys fluent. It seems like even if I initialize the fluid domain to have both zero pressure and velocity throughout the entire domain, the velocity immediately fills up the entire domain right at the first time step of the simulation instead of showing the development of the flow over time. This doesn't look physically correct to me. What are some possible issues or am I just mistaken?
skbake94 is offline   Reply With Quote
Old   September 2, 2024, 23:35
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
If you are using an incompressible fluid then the fluid in the pipe must start moving once fluid enters the inlet. Without fluid exiting at the outlet you would break conservation of mass.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
2d pipe, cfd, fluent, pipe flow
SU2 incompressible laminar flow mkulcsar SU2 3 April 30, 2023 23:59
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
Boundary conditions of laminar flow in pipe alireza.glz OpenFOAM 4 May 27, 2019 06:03
Is there a correlation for Nu number in laminar pipe flow with constant wall heat flu Shomaz ul Haq CFX 5 June 19, 2017 09:04
First steps - laminar flow in a pipe Maria Phoenics 8 November 27, 2001 12:26
