August 28, 2024, 14:54 |
Received signal SIGSEGV
Mohammad
Rep Power: 2 |
Hi there,
When I am using C_YI_G(cellg,threadg,0) (line 10) in rest of DEFINE_EXECUTE_AT_END Macro: (which written to get gradient of concentration of water(0)) 1) real delphig[ND_ND]={0.,0.}; 2) d = Get_Domain(1); 3) tg = Lookup_Thread(d,5); 4) begin_f_loop(fg,tg) 5) { 6) cellg=F_C0(fg,tg); 7) threadg = THREAD_T0(tg); 8) F_YIg= F_YI(fg,tg,0); 9) C_YIg= C_YI(cellg,threadg,0); 10) NV_VS(delphig, =, C_YI_G(cellg,threadg,0), /, 1.0); //i dont know if it is correct way of vector assigning 11) } 12)end_f_loop(fg,tg) FLUENT abnormally is exited. the error in log is Received signal SIGSEGV I try to solve my problem by Adjust Macro and UDSI_G but the same result i get. Even, i set (rpsetvar 'species/save-gradients? #t) but the error can't remove. Any idea of you surely helps me to get gradient of the concentration in a boundary thank you in advance |
concentration, gradient, sigsegv, vector |
Received signal SIGSEGV and BAD TERMINATION | ali.ashouri | Fluent UDF and Scheme Programming | 1 | September 21, 2022 00:31 |
Node 0: Process 15088: Received signal SIGSEGV. | hasib61 | FLUENT | 7 | September 4, 2022 01:25 |
Process 10300: Received signal SIGSEGV | metaliat93 | FLUENT | 2 | January 28, 2020 00:53 |
error: Received signal SIGSEGV | ianziti92 | Fluent UDF and Scheme Programming | 2 | December 5, 2018 16:25 |
define_wall_functions density and dynamic viscosity | Ionut G | Fluent UDF and Scheme Programming | 3 | March 15, 2017 10:10 |
