Issue with Centrifugal Pump Simulation in ANSYS Fluent - Fluid Not Rotating
Old   August 22, 2024, 05:22
Default Issue with Centrifugal Pump Simulation in ANSYS Fluent - Fluid Not Rotating
Merzougui Mustapha
Mustapha@ is on a distinguished road
Hello everyone,
I'm currently working on a simulation of a centrifugal pump using ANSYS Fluent. I’m relatively new to the software and could use some help. I've extracted the fluid domain, including the volute, impeller, and two pipes (inlet and outlet). Below are the key characteristics of my pump:
Mass Flow Rate: 125 kg/s at the inlet
Outlet Pressure: Fixed at a level corresponding to a manometric head of 50 m
Fluid: Water with a density of 1000 kg/m³
Rotational Speed: 1450 rpm
I've followed these steps in setting up my simulation:
Creation of Fluid Domain: I used SpaceClaim to create the fluid domain from the imported geometry and removed unnecessary details.
Boundary Conditions: Defined as specified above.
Simulation Parameters: I activated the k-omega SST turbulence model and set strict convergence criteria. I initialized the calculation with approximate conditions.
photos
https://postimg.cc/gallery/CR9Y6P9
However, I’ve noticed that the fluid does not appear to be rotating as expected, and I’m unsure where the problem lies. I’ve attached a screenshot of my setup and simulation results. Any advice on what might be going wrong or steps I should take to troubleshoot this issue would be greatly appreciated!
Thank you in advance for your help.
iter continuity x-velocity y-velocity z-velocity k omega head time/iter
386 1.0185e-07 5.0561e-05 6.7670e-05 3.4973e-05 8.3649e-04 1.0046e-03 6.2965e+01 1:54:54 214
387 1.0095e-07 5.0106e-05 6.6791e-05 3.4710e-05 8.2631e-04 9.9882e-04 6.2977e+01 1:54:56 213
! 387 solution is converged
Registering ReportDefFiles, ("C:\Users\MYC\Desktop\Mustapha\Nouveau dossier\Nouveau dossier\projet_files\dp0\FFF\Fluent\.\head-rfile.out" "C:\Users\MYC\Desktop\Mustapha\Nouveau dossier\Nouveau dossier\projet_files\dp0\FFF\Fluent\.\p-out-rfile.out" "C:\Users\MYC\Desktop\Mustapha\Nouveau dossier\Nouveau dossier\projet_files\dp0\FFF\Fluent\.\p-in-rfile.out")
Writing "| gzip -2cf > SolutionMonitor.gz"...
Writing temporary file C:\Users\MYC\AppData\Local\Temp\flntgz-137282 ...
Done.
Writing data to C:\Users\MYC\Desktop\Mustapha\Nouveau dossier\Nouveau dossier\projet_files\dp0\FFF\Fluent\FFF.ip ...
x-coord
y-coord
z-coord
pressure
x-velocity
y-velocity
z-velocity
k
omega
hyb_init-0
hyb_init-1
Done.
Calculation complete.
Writing to DESKTOP-MUSTAPHA:"C:\Users\MYC\Desktop\Mustapha\Nouveau dossier\Nouveau dossier\projet_files\dp0\FFF\Fluent\FFF-7.cas.h5" in NODE0 mode and compression level 1 ...
Grouping cells for Laplace smoothing ...
1929644 cells, 4 zones ...
4705091 faces, 22 zones ...
931252 nodes, 1 zone ...
Done.
Done.
Writing to DESKTOP-MUSTAPHA:"C:\Users\MYC\Desktop\Mustapha\Nouveau dossier\Nouveau dossier\projet_files\dp0\FFF\Fluent\FFF-7-00387.dat.h5" in NODE0 mode and compression level 1 ...
Writing results.
Done.
Mustapha@ is offline   Reply With Quote
centrifugal pump
axial piston pump simulation in Fluent Silence FLUENT 6 September 13, 2024 06:49
Rotating motion simulation in fluent yusuf.5ayat ANSYS 0 January 10, 2017 07:18
Convergence issues for a 3D Centrifugal pump simulation using ANSYS CFX enr_venkat CFX 7 August 31, 2016 19:58
Problems with rotating machinery (Centrifugal Pump) in FLUENT RR2 FLUENT 1 January 17, 2016 06:23
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
