radial component of the velocity in species transport |
August 21, 2024, 07:21 |
Ramesh M
Rep Power: 4 |
I'm trying to numerically validate the propane-co-flow experiment from Sandia lab (https://tnfworkshop.org/data-archive...et/propanejet/). From the literature, I have found that the standard k-epsilon model doesn't capture the velocity accurately, and the modification of C_1epsilon from 1.44 to 1.6 captured the velocity field comparable to the experimental results. However, the radial component of the velocity is way off from the experimental results. I also couldn't find much literature related to the non-reacting flows. I also tried a few other turbulence model modifications, but the velocity's radial component does not match. Can anyone here suggest anything, or if they have tried this already, can you suggest what I'm missing? I have attached the image of my domain if that helps. Thanks in advance. |
fluent, k-epsilon model, non-reacting flow, propane co-flow, turbulence model |
Modelling Biomass Combustion via Species Transport | Racheal | FLUENT | 39 | January 8, 2022 07:42 |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
OpenFOAM extended 4.0 Error with Multinode Set-up | Liweix | OpenFOAM Running, Solving & CFD | 1 | February 18, 2020 00:50 |
Species transport simulation in cyclic flow | SH_P | FLUENT | 0 | May 29, 2015 11:15 |
user defined scalar vs species transport | gvj_mech | FLUENT | 0 | March 27, 2014 14:33 |
