August 18, 2024, 06:53 |
Combustion
I have an engine I used Partially Premixed Combustion - Flamet generated manifold. I started the combustion by patching progress variable to 1. But I want to remove the patch after a while to get more accurate results. But when I remove the patch temperatures drops and combustion ended. How can I continue to combustion without patching the progress variable to 1 ? I already tried to made patch with high temperature but it didn't worked. |
August 27, 2024, 04:51 |
Refik
Rep Power: 11 |
Setting the progress variable to 1 is actually used quite often. You can also try patching mixture fraction. If your simulation is in steady state, you can try patching a larger volume onto a mixing region in your domain and create a hot mixing region where hot gases have larger residual time. There should be no need to "remove the patch" as it will adjust and remove itself along with iterations and incoming flow. |
combustion |
OpenFoam Combustion SIG | dlahaye | OpenFOAM Announcements from Other Sources | 0 | August 14, 2023 12:39 |
How to use UDF/DPM to conduct combustion of boron particles? | Mike08 | Fluent UDF and Scheme Programming | 0 | April 19, 2023 10:55 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 05:10 |
Partially Premixed Combustion - Direct Fired Boiler | oknus | FLUENT | 0 | April 10, 2012 11:52 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 19:40 |
