August 13, 2024, 13:15 |
Diifuse Fraction Value
Rep Power: 3 |
I am simulating solar radiation incident on water passing between two layers of quartz glass. I am using DO radiation model, and I want to know what is the diffuse fraction value that I should use for every surface (Upper glass surface - Glass-Water interface, etc.). I tried to find such a value online, but unfortunately, I could not. Changing the value from 0 to 1 is changing the results abruptly. What is your advice on this value. Thanks a lot. |
glass radiation, glass radiation proprties, radiation do model, radiation heat transfer, solar radiation |
multiphaseEulerFoam FOAM FATAL IO ERROR | qutadah.r | OpenFOAM Running, Solving & CFD | 11 | December 10, 2021 20:18 |
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) | remidemol | OpenFOAM Running, Solving & CFD | 3 | May 26, 2020 05:47 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
