July 31, 2024, 06:53 |
Direct-flow cyclone
Valery
Rep Power: 2 |
want to simulate the motion of a discrete phase in a dirert-flow cyclone. The goal is to obtain a contour of the DPM concentration. The task is stationary. At first, I wanted to obtain a contour of the velocity in the apparatus and used the k-e RNG and Realizeable models for this. But the calculation does not converge at any settings, an error appears "floating point error". The gas velocity in the apparatus flies away to 10^5 m/s. When using the k-w SST model, the velocity calculation is complete.
When turning on the stationary DPM model, the calculation does not converge either when using the k-e models or when using the k-w SST model. When turning on the k-w model, the calculation did not complete even after 500 iterations, I stopped it manually (the velocity is again 10^4 m/s). 1. Why does the k-e models not simulate the velocity profile in the apparatus? 2. How to set the parameters of the DPM model so that the calculation converges when using the k-w model? How many iterations might this require? I can send you a file of the solid or parasolid model. Thanks for your help, this is my first task in Ansys [IMG] https://i.ibb.co/2KzRCbB/image.jpg https://i.ibb.co/x3W612t/kw-vel-contour.jpg https://i.ibb.co/D8NXrNT/kw.jpg https://i.ibb.co/B37WKHm/ke-vel-real-countour.jpg https://i.ibb.co/LtpYdYQ/ke-real.jpg https://i.ibb.co/fvVqZmC/kw-with-par...el-contour.jpg https://i.ibb.co/Ng01S01/kw-with-particle.jpg [/IMG] |
direct-flow cyclone, dpm concentration, k-e models, k-w sst |
Is recirculating flow is free vortex or forced vortex? | FluidKo | Main CFD Forum | 11 | July 21, 2022 07:21 |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 18:22 |
viscosity of fluid and impact on flow on a fixed supply line | Henry04 | Main CFD Forum | 1 | December 27, 2021 22:31 |
Reversed flow cyclone | Mohsin | FLUENT | 0 | August 7, 2012 21:46 |
help! too highly swirling flow in a cyclone | lcw | FLUENT | 1 | November 22, 2005 09:17 |
