Issue with Residual Oscillations in SIMPLE Scheme at Low Viscosity |
July 23, 2024, 15:08 |
Vinay
Rep Power: 2 |
Hello everyone,
I'm encountering an issue while running a simulation of a piping segment using the SIMPLE pressure-velocity coupling scheme in ANSYS Fluent. Here are the details: - When I run the solution with a low viscosity value, the residuals oscillate after a few iterations, including the monitored parameters. - However, when I run the same Fluent settings with a higher viscosity value, the solution converges without issues. Monitoring Setup: - Flux report to monitor the flow rate. - Surface report to monitor the pressure. Questions: 1. Causes of Residual Oscillations: - What could be causing the residuals to oscillate at low viscosity values? - Are there specific areas in the simulation setup or model parameters that I should investigate first? 2. Stabilizing the Solution: - What are the best practices for stabilizing the solution when using low viscosity values in the SIMPLE scheme? - Should I consider adjusting any specific solver settings, under-relaxation factors, or mesh refinements? 3. Monitoring Parameters: - Are there additional parameters that I should monitor to better understand the cause of the oscillations? - Any recommendations on how to set up effective monitoring to diagnose and resolve convergence issues? 4. General Advice: - Any general advice or tips for troubleshooting this type of behavior in ANSYS Fluent simulations? Thanks in advance for your help! |
impact, residual convergence, viscosity |
#0 prinStack(Foam::Ostream&)sh:1 addr2lin: not found addr2line failed | jerrry51 | OpenFOAM Running, Solving & CFD | 0 | September 2, 2022 14:33 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
