How can TKE help me in explaining flow separation happening in an airfoil? |
July 20, 2024, 02:18 |
Anupam Krishnan
Rep Power: 5 |
Hi all,
I am doing URANS simulation to study the effect of turbulence intensity on NACA 2414 airfoil at a Re of 100000. The lift coefficients increase with the increase in TI for an AOA of 20 deg, and the drag coefficients decrease with an increase in TI. How can the TKE plots be used to explain flow separation and variation in aerodynamic coefficients? I am adding TKE plots at 20 deg AOA. Last edited by yujin_cfd; July 20, 2024 at 02:20. Reason: To add figures. |
July 20, 2024, 12:00 |
Lucky
Rep Power: 66 |
I think it is meaningless to discuss physical explanations when you have a discontinuity in your tke plots caused by the grid! How can you explain a change in the tke when you didn't change the tke?
July 21, 2024, 07:18 |
Anupam Krishnan
Rep Power: 5 |
Thanks for the reply.
Consider me a beginner. I have 2 questions on your reply. 1. What do you mean by discontinuity caused by the grid? If I take it into CFD Post, I am still able to get a continuous contour for the TKE. 2. Changing the Turbulence Intensity basically changes the TKE for the flow as well right? Can I assume that high TKE is associated with flow separation and dissipation? |
airfoil 2d, tke, turbulent kinetic energy, urans model |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Separation Flow Over an Airfoil | hossein66 | FLUENT | 0 | December 9, 2016 03:08 |
Will "filling" areas with re-circulation always eliminate that flow separation | Michael B | Main CFD Forum | 9 | September 1, 2016 13:43 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
