Problem with reactive flow simulation [species model] |
Rep Power: 0 ![]() |
Hi, I am encountering a problem with using the species model in Fluent.
I have a stirred tank reactor where I want to simulate a 2 step reaction (Villermaux-Dushman in my case). The reactor has 2 inlets and 1 outlet, I am running the simulation in a steady state flow. The stream A contains IO3-, I- and H2BO3- and stream B contains H+, I suppose that the stream properties are the same of that of water and specify the following initial concentrations : - [H+]=0.04 kmol/m3 -[H2bo3-]=0.0909 kmol/m3 -[I-]=0.0117 kmol/m3 -[IO3-]=0.00233 kmol/m3 The first reaction is a neutralization reaction (instantaneous) : H+ + H2bo3- -> H3bo3 and the second one is : 5I- +IO3- + 6H+ ->3I2 +3H2O I enable in Fluent the species transport model with finite rate model, but the results I have make no sens since I have at the oultet a molar concentration for [H3BO3] =0.6kmol/m3 far superior than the initial specified concentration of [H+] Another thing that is weird is that it seems reaction 1 and 2 take place in the inlets but I have separated the reactants so it shouldn't be the case. Any help would be much appreciated ! |
finite rate chemistry, reacting flow, reactors, species transport model, turbulent flows |
Looking for freelancers to deal with particle laden flow simulation problem | EvanHuang | CFD Freelancers | 0 | September 10, 2019 01:09 |
Pipe flow simulation problem with pisoFoam: not getting parabolic profile | sahmed | OpenFOAM Running, Solving & CFD | 1 | September 7, 2016 14:00 |
Problem with pipe flow simulation with wedge shaped domain and recirculation bubbles | sahmed | OpenFOAM Running, Solving & CFD | 0 | August 17, 2016 14:56 |
problem of reactive flow | llnudt | FLUENT | 1 | January 16, 2007 14:19 |
exemple of simulation results in reactive flow | GACEM_hatem | Phoenics | 0 | June 6, 2001 14:13 |
