July 18, 2024, 16:02 |
Interface between 4 cell zones
Arun raj.S
Rep Power: 16 |
I am simulating printed circuit heat exchanger. Here, I am encountering a situation in which I need to create a non conformal interface between 4 cell zones (2 zones on one side and 2 zones on other). The two zones on one side has one solid and one fluid cell zone whereas the two zones on the other side also has one solid and one fluid zone. Is it reasonable to create non conformal interface between multiple zones with multiple zones. Or is it compulsory the interface has to be always one to one. In my opinion, multiple (solid solid, solid fluid, fluid fluid) vs multiple (solid solid, solid fluid, fluid fluid) should not cause any issue. Can someone clear my doubt
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 13:25 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
