TKE hand calc for SST
Old   July 16, 2024, 07:41
Default TKE hand calc for SST
Svetlana Tkachenko
Svetlana is on a distinguished road
Hi All,
I've found these two threads
turbulent kinetic energy
How to obtain turbulent kinetic energy data from LES model of Ansys CFX?
The resolved component of TKE, in the context of the above discussions related to LES modeling, is calculated as follows:
k=0.5*((RMSE x velocity)^2+(RMSE y velocity)^2+(RMSE z velocity)^2)
In my simulation I'm using the SST k-omega model. The TKE value provided by fluent is about 2.5 times different from the value calculated using the above formula. How does fluent calculate it, then? TIA.
Svetlana is offline   Reply With Quote
Old   July 16, 2024, 11:47
Luca
xisluke is on a distinguished road
Maybe I didn't get the point, but it seems you are trying to compare a TKE coming from a resolution of a transport equation for RANS (k transport equation in k-omega SST model) with a formulation where at least the main portion of the eddies is directly solved, thus it is embedded in the X, Y and Z components of the velocity.
xisluke is offline   Reply With Quote
Old   July 16, 2024, 22:59
Svetlana Tkachenko
Does the formula quoted above not apply to solutions calculated with the SST k-omega model, then?
Old   July 17, 2024, 08:07
Luca
No. Adopting an eddy viscosity model like k-omega SST or k-epsilon means running a RANS analysis where the turbulent kinetic energy is completely modeled. RANS and LES are two very different approaches.
Paper for boundary condition of turbulence intensity at inlet FluidKo Main CFD Forum 22 June 27, 2022 00:29
Under prediction of TKE behind triangular cylinder ckpark OpenFOAM Running, Solving & CFD 0 April 22, 2022 18:36
[LES] Estimating resolved TKE from instantaneous velocities Gerry Kan Main CFD Forum 14 March 23, 2022 07:58
Resolved TKE budget terms calculation from LES Simulations Agavi Main CFD Forum 11 June 2, 2021 17:13
Tke pike rg12g09 STAR-CCM+ 0 December 6, 2011 10:51
