Does radial velocity exist in pipe flow? What is its magnitude? |
July 14, 2024, 12:22 |
mengyue
Rep Power: 17 |
Dear all,
I have been using Fluent software recently to simulate air flow in a circular pipe with a diameter of 0.0127 centimeters and a length of 1.02 meters. The air is treated as an incompressible fluid, and the inlet velocity is set to 12m/s, resulting in a flow Reynolds number of approximately 10,000. This is a classic flow problem where, if the fluid flow direction is designated along the x-axis, the ux (velocity in the x-direction) exhibits a parabolic distribution radially. However, I'm puzzled about the uy (velocity in the y-direction) values. I compared the ux, uy, turbulent kinetic energy (tke), and dissipation rate (eps) at the mid-section of the pipe with a reference paper (see Figures 1-4), where OSU represents the results from the literature. It can be observed that the comparison for ux, tke, and eps is excellent, showing good agreement. Nevertheless, the uy values I obtained are significantly smaller than those in the literature. I have confirmed that the literature uses a two-equation turbulence model and enhanced wall treatment, which I have also adopted in my settings. However, there is a substantial discrepancy in uy. May I inquire about the possible reasons for this and what parameters I should adjust to achieve results closer to those in the literature? |
July 14, 2024, 12:34 |
mengyue
Rep Power: 17 |
I am very sorry that there is something wrong with the figure. And the detailed information is that (just for uy);
The uy in my case is about 10^-6 m/s, while the corresponding value in the reference is about -0.002m/s-0.0015m/s. Would you please tell my why and how can i get the same values as the reference paper? Thank you in advance! |
pipe flow; uy; |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 19:11 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
Boundary condition of velocity and pressure at interface for air water pipe flow | jignesh_thaker2007 | OpenFOAM Running, Solving & CFD | 0 | June 10, 2014 17:42 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 23:34 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
