Yaser
Rep Power: 0 ![]() |
I have two questions that needs clarifications. 1. Does species transport support periodic Boundary condition? Because I would like to simulate a species transport problem and observe the flow due to gravity in a vertical pipe. If periodic BC works, then I don't have to create a longer pipe (Viscous Model - Laminar) 2. I was simulating a species transport problem in a horizontal pipe and was analyzing the flow due to gravity. I want to apply wall BC to the inlet, outlet and pipe wall because I want to have a static pipe with zero velocity. So after standard initialization from the input, i tried to patch a constant pressure value across the domain. But when i looked at the pressure contour it shows zero. I tried changing different pressure values but still the same. Can anyone help me on how I can patch a pressure across the domain with the above said boundary conditions? (Viscous Model - Laminar) |
initial condition, initialise, initialization, patch by zone, species transport model |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
Please help!! Patch and Species transport | Julie | FLUENT | 5 | August 3, 2016 03:10 |
