July 2, 2024, 19:37 |
Pressure drop due to pump
karl
Rep Power: 2 |
I need to calculate the pressure drop across a vertical pipe with a pump, the problem is I have no clue how to add the pump. The pump has a flowrate and a pressure given( 3PGM and 55psi). I don't know how to include it such that the pressure drop reflects it. I know there is a way to use a momentum source to model a pump, but I don't know how this will affect my pipe. All help would be useful. the geometry is very simple (a cylinder as a pipe). |
July 4, 2024, 04:05 |
#2 | |
Luca
Rep Power: 5 |
If you need to do a check with Fluent you can impose a fixed velocity at the inlet of the pipe and a fixed static pressure at the outlet, the code will evaluate the drop that the pump will need to overcome. |
July 7, 2024, 14:07 |
karl
Rep Power: 2 |
According to my calculations, the pressure drop is calculated using the energy equation, where the driving pressure change is due to head loss from a pump. the potential and frictional parts play a role as well, but not as significant. My problem is I cannot find a way to show this in Fluent.
At the inlet: I put flowrate (as a velocity) at the pumps pressure (55psi or 380Kpa) At the outlet: I keep that at 0 gage pressure Yet for what ever reason the answer is never close to that and is around 1Pa which is the frictional loss in the pipe. |
ansys, fluent, pressure, pumps |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
OpenFOAM - cyclicAMI Pressure drop result variation | Vishsel | OpenFOAM | 0 | May 31, 2019 02:47 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
