July 1, 2024, 05:03 |
monitored value do not converging
Qin Yajie
Rep Power: 2 |
Now I am simulating an axial Fan in wind tunnel refer to the ISO5801 type C. In order to get the fan P-Q curve, the inlet total pressure (a point on the axis 1m upstream the inlet plane Pt) is monitored. My question is that the Pt does not converging after few hundreds steps. The test valve is 252Pa, the simulated Pt jump around 250 Pa and has an amplitude about 30Pa.
I do the simulation with FLUENT 3d steady simulation. The simulation domain consists of three zones one inlet chamber zone, one rotating fan zone(MRF method 1486rpm) and one ambient outlet zone. Other simulation as flowing:
convergence, monitor solver, sst-kw |
Moment monitor not converging in transient simulation | saikath65 | FLUENT | 0 | August 21, 2020 08:58 |
[Workbench] Converging problem with hyper elastic material | sarbakhshian | ANSYS Meshing & Geometry | 0 | April 24, 2020 16:31 |
Maximum value of monitored report value | SirIsaac90 | STAR-CCM+ | 1 | April 10, 2018 05:46 |
strange residuals - converging -then diverging- then oscillating - then getting weird | juste | FLUENT | 3 | December 3, 2016 17:26 |
My steady state solution converges for a while but stops converging | C.C | Fluent UDF and Scheme Programming | 0 | October 9, 2013 11:11 |
